Which 6800nu?
PornFlake
CC has the BFG for $299 minus a $50 rebate = $249
Outpost has the PNY for $249 straight up.
Any thoughts on which one to choose? I am replacing a 128 MB 9800 NP.
Unlocking the pipes/VS and OC'ing are important to me.
-Flake
The PNY will overclock to the OC's speeds, but there is no guarantee that' it will go much further.
I have a PNY 6800NU, and it's great. No regrets. I don't care for a warranty, because I'm going to get a new card in less then a year anyway. Not to say that PNY doesn't have okay customer support, I just havn't looked into it. I havn't owned a BFG 6800nu, and I don't think anyone who has a BFG owns a PNY, so you can't really get a good viewpoint from anyone here.
Anyway, the only thing you're going to get from people here is bias. But if a lifetime warranty, and said "great technical supprt" is worth it to you, go with the BFG.
Anyway, performance. Mine OC's to 400+/900 when nothing is unlocked. While unlocked, it can do 350/900. It can go higher, but I don't like pushing it in a sonata. On this forum, I've seen probably 2 people with a PNY 6800. One of them, IIRC, had his mem at 900+, and a 400 core unlocked. The other had a decent overclock, too.
Also, I hate rebates. Damn things usually take forever to go through, and get shipped to the wrong address...I'd go with the PNY.
I have the same card,it doesn't OC quite that high but it gets close and it has GDDR3 memory and unlocks so I'm happy with it.The ability to unluck the pipes is purely luck,although it seems PNY has a higher instance of being able to do it,but that's just an observation on my part.
Chris
Ryland said:
BFG. It has a lifetime warranty vs PNY's 1 year warranty.
PNY doesn't have a 1 year warranty. They have a "lifetime" warranty, meaning they warranty the product for the product's lifetime in the market. That could be one year, that could be four years. Most times it is significantly longer than one year though.
If I were buying one now, and I would if I had the money, I would buy the PNY 6800NU for $249.99 @ outpost.com.
CC only sells eVGA not BFG.
-Flake
