Which 64-bit Firefox is better?
army
Hi,
Ever since I've been using Vista x64, I've found there are two 64-bit Firefox versions.
http://wiki.mozilla-x86-64.com/Download
http://www.vector64.com/WindowsBuilds.html
I've been using the one from Mozilla-x86-64.com and everythings been fine, except for the occasional crash and the current bug in the search bar.
I was wondering if anybody (who has is running Vista x64) have used the Vector64.com's version, or both for that matter and if you had any opinions as to which one is overall better?
Do you even use these specially built versions of Firefox? Or do you just use normal download from mozilla.com/firefox?
thanks!:)
I used a x64 build long ago, but ditched it simply because it wouldn't work with any of the plugins I use. Ever since, I've just gone with the regular package from mozilla.com.
Running Vista x64
Same with IE7, it seems like there's no pros to using the x64 version, but plenty of cons.
Yea, i would think something as lightweight as a web browser cant really be any faster. Loading web pages isnt exactly processor intensive.
