[ame="http://www.amazon.com/StarTech-com-Port-Controller-Adapter-PCISATA4R1/dp/B0001Y7PU8"]Amazon.com: StarTech.com 4 Port PCI SATA RAID Controller Adapter Card PCISATA4R1: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/21G8X9DS2NL.@@AMEPARAM@@21G8X9DS2NL[/ame]
I just bought one of these to expand the number of SATA drives in my computer. I am not using it for raid, even though it has software raid included (suspect it's not very robust anyway). The problem I have is that for the drivers there is a 64 bit folder and a 32 bit folder. Under the 64 bit folder (my computer uses Windows7-64) there are two sub-folders and I am not sure which to use. Anybody know? The two sub-folders are "ext64" and "ia64" I am guessing that one is for raid and the other is for non-raid. The manual and the readme are absolutely no help.
