matrix563
- Sep 1, 2006
will let me run 3 x 1920x1200 monitors in portrait? like my current asus 680 does?
i was considering this but i don't know if the vga supports 1920x1200 or if it even does 3 monitors in portrait
http://www.galaxytech.com/__en_gb__/Product309.aspx
i might be down grading my rig and i want to keep watching videos across my 3 1920x1200 monitors in portrait for a 3600x1920 resolution
not looking at an amd solution. i like the 3 dvi on the 680, it just works. no dp dongle crap. running 2 cards is not an option either. that doesn't work properly
