matrix563
- Sep 1, 2006
I'd like to test eyefinity with the 5450. If the card doesn't have display port that means no eyefinity?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102877&cm_re=5450-_-14-102-877-_-Product this is the cheapest one, a sapphire. only vga, dvi and hdmi. can the vga subsitute for DP?
i think this powercolor http://www.newegg.com/Product/Product.aspx?Item=N82E16814131345&cm_re=5450-_-14-131-345-_-Product
and this xfx http://www.newegg.com/Product/Product.aspx?Item=N82E16814150470&cm_re=5450-_-14-150-470-_-Product
would probably both do it fine since both have Display port. thoughts?
