Which 5.1 speakers
3erious
hi,
i am thinking of buying some 5.1 speakers for around £150-200, i was first set on buying a set of z-5500 but reading this forum people say the klipsch is also good. so which of the following is the best speaker set.
logitech z-5500
or
Klipsch ProMedia GMX D-5.1
I will use them mostly for movies and a bit of gaming.
thanks
3erious
after a bit of research i found out i cant use these speakers with by audigy 2 because it doesn't have an PCM inputs. Only way i could connect is if either convert to Coax or have a soundcard with S/PDIF out if you want 5.1.
3erious
logitech z-5500 All the way, its the best set of speakers i ever had. The Bass kicks ass for movies.
Currently have my PS3 + Xbox360 + Pc hooked up to it all at once.
I have Promedia Ultra 5.1, old school but very nice.
I bought a set of the Logitech z-5500 for my son, the nice thing is they have both analog and digital inputs..............he can plug his computer to the analog and his XBox 360 via the optical toslink.
Those Logitechs will rattle the windows.:eek:
