The Real Zardoz
- Jun 29, 2002
As per title.
I currently use a Sony G520. I had a Dell 2405FPW for a short while - I noticed the lag straight out of the box, so it went back to Dell for a full refund. I liked the size, but found the screen a bit bright for me, plus I could feel the heat it was belting out in my face!
I have always liked the Apple Cinema displays - especially the 30" (I reckon the 30 has it all over the 23 for colour). I do perfer the S-IPS panels as well.
I owned a BenQ FP202W for a few days until my brother decided he wanted it to replace his failing Sony G400. I loved that screen - although the colours needed a bit of fiddling due to the brownish tinge the white had, but side-by-side to my CRT, I reckon the panel was nicer to look at. Bit of viewing angle botheration up/down but side/side was fine unlike the Dell.... response time was perfect to me. The BenQ was too small, though.
I had a look at a Dell 2405 the other day - despite the lag, I love the colour range and contrast that panel had. However.. lag puts that out of the running.
I understand the BenQ is of a newer generation S-IPS panel than the 23" LG-Philips offerings. I am considering an HP L2335 although I am worried about the older gen panel.
Is there a newer gen 23" panel out by LG-Philips? I'd go the 30" Dell (I understand these are S-IPS, too) but they're a bit pricey and lack a second input as I tend to use multiple inputs on my screens at the moment (including VGA).
Graphics card is a 7800GTX. I run at 1600x1200 on my G520 at 100Hz.
