if you are willing to or want to use a widescreen then the NEC 20.1" widescreen has every input you could ever want, plus it is an amazing, albeit expensive, monitor
Westinghouse 22" at bestbuy
- Retails for $480 (was on sale at $399)
- 6bit panel
ASUS PW201
- $550ish
- Limited view angle
NEC 20GWMGX2
- $650
- Very fast reponse time
- Twinkling/Fuzz over analog inputs (component)
"Nec 20WGX²: Its initial color quality is very good and most importantly its the only really fast monitor in 20 inches. No other competitor is able to compete in games. Unfortunately, it has downsides as big as its advantages. We don´t like the glossy treatment on the panel and the twinkling effect in videos." - http://www.behardware.com/articles/619-18/updated-survey-13-lcd-20-5-6-8-16-ms.html
I'm thinking of getting either the ASUS or NEC. My brother has the NEC and I like it, but the components aren't really useful because it has issues with analog inputs (component). You can see twinkling/horizontal lines in the image. The ASUS is tempting and cheaper, but it has a limited viewing angle, supposidly something like 91 degrees vertical compared to most screens with 170 according to pcworld. (http://www.pcworld.com/product/specs/id,28548-c,monitors/specs.html)
I have the Acer Ferrari at work and its definately a pretty monitor. Its only about $400 so I'm also thinking about it. I really want component inputs though, but I guess its not that big of a deal for me cuz I can just use VGA cables for XBOX 360.
