Where's my Doom bottleneck: 2xAGP or CPU?
pmrogers
System: Athlon 2200, Abit mobo (don't know model but it's 2x AGP, 266mhz bus), 512Mb PC2500, 9700 Pro 128mb.
I'm not getting the framerates or consistency I'd like on Doom 3, even at 640x480 and low quality settings. I'm willing to spend about $100 upgrading IF it can get me to the liquid smooth play (at 640x480 low) I experience on my big rig p4 3.0c+6800Ultra.
Will upgrading to a 2600+m or an 8xAGP mobo get me enough of a boost? I'm pretty sure the video card is okay since it was delivering 50fps in the p4 system.
Thanks in advance for any suggestions.
Paul
I would actually be suprised if it was the AGP. Even for Doom3.
Do you have all your motherboard Drivers installed and up to date? Direct X 9.0c? etc.
==>Lazn
It's certainly not the video card...but could possibly be due to the 2x AGP. I would get a newer mobo, like the NF7-S, and then try it out. If it's still not running great, then you can always upgrade the proc.
Thanks for the responses, guys. As far as determining whether 2xAGP is the problem, do you think the following would be a valid test?
On the p4 6800 system throttle back to 2xAGP in the nVidia drivers
Play/timedemo Doom on 640x480 low quality
If this caps at around 35fps and is slightly hiccup'y like the Athlon then it seems it would be safe to assume that 2xAGP is the problem. On the other hand, if it runs flawlessly, would this necessarily mean that it's the CPU vs. memory or some other issue?
Cheers,
Cheers,
That sounds like a plan.
==>Lazn
