CyberDeus-RagDoll
- Nov 1, 2006
So...
Sorry that this went in general hardware, but I've got no idea where else would be appropriate.
Anyhow.. I'm sitting at my screen today, and just noticed a little spec bug ("no-see-um") wandering around on my screen.
I go to brush it off (believe it or not, I have a microfiber soft brush just for dust on the pc)
and find out the things UNDER THE PLASTIC of my 37" westy.
It's moving, so, it's definately not a stuck pixel.
Apparantly, there are BIG GAPING HOLES in the back of my screen for all sorts of creatures to crawl into (I mean, it wouldn't fit a gecko, but some mosquitos? hell yeah.
Now, that might be all well and good, but I guess the front plastic (that's between the actual LCD part and the "outside world") must not be sealed either.
So, I'm wondering, is there something I can, I don't know, spray on the back of my lcd (around the vents, etc) that will scare off insects and not also damage the screen?
Personally, I'd consider this a design defect, since they don't have the "user area" protected, but I doubt westinghouse will "get rid of the bug" for me, and I don't want to have to send the screen off because of a no-see-um, that's turned into a definately-see-um.
