where to put which fans?
Dome
i'm going to buying my rig soon, the case (antec) comes w/ 2 fans and has room for 4, all 80 mm. i'm buying 3 sunons (newegg is out of panaflo) and one is for the slk 947
anyhow i was wondering assuming the sunons draw much more air than the antec stock fans, and there are 2 fan slots at the front and 2 in the back, should i put one sunon in the fron and 1 in back? or both in front or both in back? thanks
the other sunon will of course go over the slk
is the sunon your buying the one thats a Vantec Tornado? If so, you dont want 4 of those puppies or else your case will sound like a jet.
Personally, I'd ditch the Antecs and get all Sunons. If you can't do that though, put the Antecs in back and the Sunons in front, like I did for a friend of mine. It just about evens out the flow with the psu factored in to the equation.
just my .02
