where to put pump??
alex paik
well, i have a tiny problem.. i have almost everything put in.. but now its crowded like a mofo in my case and i have no where to put my pump.. can anyone think of anything?
and i think my case is too small because i think anywhere i put tubing, it's going to kink.. anyone have an a8n watercooled?
btw, i will also have a maze4 low pro gpu block.. add that into the mix.. thanks!
edit - i do have two single 120 rads.. does the d5 have to be mounted right side up?
hmm, i thought someone might say that.. i forgot to mention that i have a ocz powerstream 600.. so the end of the psu butts up right to the drive cage..
Mount it to the top of the case using some black button head socket cap screws. Or another place is right in front of the radiator and the CPU block.
id rather not mount it on top of the case.. maybe ill try to mount it in front of the rad..
well do you have a pic?
Get rid of the D5 and get a DCC? Should fit right nice under your HD or inbetween the rad and HD rack.
what about moving the hdd rack? btw the DDC is not a weak pump, but the D5 is still better.
i already drilled new holes to move the hdd rack.. i will have two fans on the bottom rad (push/pull).. the fan will butt up to the hdd rack.. i was thinking having the pump facing backward.. how tight can the tubing be before it kinks? i have tygon 1/2 inch..
if it's at least a 3/32" walled tube you should have at least a bend radius of 2-1/4"
