- Apr 27, 2006
I have 2x Raptor's in RAID 0 and a 320GB 7200.10 SATA2 Seagate hdd. The OS is on the raid; is it still better to set the pagefile on the single hdd even though it is much slower?
put it on a separate HD then your OS
Maybe if you have a server mobo or something with more than 8 gigs of ram in it, but even with 4 gigs of ram i see that making little sense.
I think it's just a placebo effect of dicking around with OS settings and you should leave it alone, as the OS configures it.
I generally have multi HDD systems, non-RAID
I set up 10GB partitions on outer tracks of each non-OS HDD to use for pagefile and scratch disk (for apps that use scratch, like PShop.
I set minimum pagefile size on OS disk.
If having the page file on the same drive as, but on a seperate to, the data being paged doesn't it cause head-thrashing since the drive had has to move between the 2 partitions? I suppose this is where multiple page files come in handy, right?
The data being paged is going in/out of memory.
It has been years (>5 drive generations) since I tried to test performance results. When I did last test, PShop was only app that seemed to produce any change (single digit %). I suppose trying to test current media manipulation apps might be in order......
If you are interested in this, you might do a search on<pagefile multiple drives>
imho: if you're shelling out $$ for raptor raid, then it's probably worth putting enough ram in so you can turn off the swap file altogether. You get a small boost out of windows not trying to pro-actively swap all kinds of stuff to the file.
In theory, swap file should be an emergency scenario, but that doesn't seem to be how windows handles it (ram is actually cache for the swapfile?).
Disabling the pagefile completely is a bad idea. Even if Windows has enough RAM, some data is still paged onto the pagefile area on the hard drive.
Sorry, but that's not correct. Running without a page file is different than running without paging; indeed, it is impossible to run without paging. But it's perfectly possible to run without a page file.It's impossible to disable the pagefile in the first place.
Incorrect.There's an inherent flaw in that statement above: if it's impossible to run without paging, then obviously the pagefile is where those pages need to go, correct?
This used to be the case, but isn't any more. Windows 2000 would create such a file, for instance. But Windows 2003 Server (and newer) and Windows XP (and newer) don't create a temporary system paging file.Windows will create a pagefile automagically, a smallish one and use it as necessary. Typically it's about 20MB and will appear in the Windows\System32 directory as required so,
You can force the page file to be preallocated. Then, it doesn't get fragmented itself, and it doesn't grow or shrink to cause fragmentation of other files on the same volume.
Fragmentation of the page file itself doesn't matter much as most I/O to it is random, anyway.
Yes. So, set it to a static page file; set it to the same min and max size. Then, reboot -- that creates the file. If you want to run a defragmenter that defragments the page file, then you can do so, but you'll have to reboot again.
I've read conflicting advice about the system-managed file not becoming fragmented, but I don't believe it. I know, for sure, that a static sized file won't fragment.
Set them to whatever you'd like. I'm not sure what good placing the file "at the first part of the hard drive" would do. What makes you think it'll move?Oh right; thank you. So when i do a clean install of Vista (with 2GB of RAM, maybe 4GB) i will immediately set the min. and max. values for the pagefile to aboue 1500MB or something, right? It's just a pitty it won't stay at the first part of the hard drive by itself.
Unless Windows allocates an amount of space equal to the max amount, I can't imagine how that could possibly work. If a file resides on a number of sectors after the end of the page file (the min value), it would necessarily have to fragment the page temporarily to accommodate that. This won't fragment the page file up to the min amount (because Windows will inevitably release allocated sectors as page usage decreases), but it will lead to possible fragmentation of files created during the time that the page file has increased in size beyond the min value.I've read conflicting advice about the system-managed file not becoming fragmented, but I don't believe it. I know, for sure, that a static sized file won't fragment.
Right. The link I'm thinking of came up the last time I had this discussion on this forum -- within the last six weeks, say. The link claimed that the page file was, indeed, preallocated to the maximum size. I don't believe that's true.Unless Windows allocates an amount of space equal to the max amount, I can't imagine how that could possibly work.
Right.If Windows is blocking out space on the drive up to the max value, then you may as well just set the min value to the max value and be done with it. With hard drive space being as cost-effective as it is today, I can't imagine why SP2 didn't force a static page file.
As you say, drive space is cheap. If a 320 gig drive costs $85, then 4 gigs of space costs $1.06. How much does E_OUTOFMEMORY cost?Oh, and it seems like some of you guys have some pretty obscene page file sizes.
Where is the head's normal static position? Are you talking about a crash prevention parking feature?
Plus, most of the latency is in settling and waiting for the platter rotation.
