I am looking to get a new water cooling setup and have not really dabbled in it since 2 -3 years ago and was wondering where you guys mount your radiator.
My problem is this, the setup I am looking at commes with a double size radiator that accomadates 2 x 120mm fans but there is nowhere I can put that and most of the single ones are 120mm as well.My case (Thermaltake xaser III (i know it's ugly)) only has 80mm fan holes - 2 at the back 2 at the side 2 at the front and one in the top and I can't find any cases that can accomodate 2 x 120mm fans without a mod.
I did think about making the two door fans holes 120mm but I dont want the radiator screwed to the door as I am likely to forget and pull on it and damage something.
Any advice?
Any advice?
