Where to Mine LBRY?
cybereality
Looking for a good pool to mine LBRY, any recommendations? I'm trying to dual mine ETH + LBRY w/ Claymore.
What To Mine says I can make $15/day on LBRY, but on Suprnova I've only brought in around $3 after 2 days.
Not sure if Suprnova is just bunk, or there is some setting I missed, but the miner is showing consistent confirmed shares every few seconds, so it appears to be working.
Any advice?
supernova is decent pretty much only one that supports the smaller coins. what to mine is bs alot though.
Okay. Thanks. An ASICS miner sounds interesting. I'll be sure to check back when it comes out and see if it's worth it.
In any case, at the current rate I'd be pulling in $45/month w/ Lbry, which is still better than w/ SiaCoin (I was getting $30/month if even that) and this would pay for the electricity at least.
For dual mining, nothing is more profitable than lbry on RX cards.
I use intensity of 31 for lbry, which doesn't bring down my ETH hashrate. GIves about 77 on lbry while dual mining.
Coinmine.pl is a good pool for lbry
Nevermind. I was entering in values wrong on WhatToMine. With my actual hashrates, it says I should make $1.20 a day with Lbry and only $0.50 w/ Sia.
Not going to retire with that money, but it's still double what Sia was pulling in, so that's something.
