I always wanted to build a dual cpu system but never have. Now I go through the dually pics thread and itching to build one on my own. I am failry competent at building computers from ground up but they always have been single cpu systems. I am currently using a 2600k oc'ed to 4.5, cooling with a corsair H-1000, 16 gig ram, raid 400gig SSD's and raid 4 TB storage drives, and also a Radeon 6970.
For my next rig, I have two options. I am either going to build it from ground up or repalce the motherboard and cpu combo on my current rig.
My questions are :
1) What kind of cpu combo am i looking for if I want to have almost twice the computing power that I have now?
2) Is a dual cpu rig going to just add additional core's to be used in parallel computing or each individual core gets faster? I mean 2 8 core cpu's make one very fast 8 core cpu or 2 normal cpus with a total of 16 cores? If it's the second, I may consider not building the rig because I need single core speed more than I need the amount of cores. In that case, I may just go get the fastest single chip I can get.
3)Some mobo recommendations?
4) Can you guys give me some example builds such as just a basic cheap one and an over the top expensive one?
5) Is it feasible to go quad cpu? Is it extremely expensive? Does it scale good?
6) Can dual Cpu system's cause trouble with software or games? As an example I use a stream conversion and uploading software called Xsplit and it does not play nice with dual chip GPU's. I am wondering if that is a common problem with dual cpu users.
Again if you guys can answer some or all of these questions, I would appreciate it.
My questions are :
