michaLcoughliN
- Jan 13, 2007
Plexiglass for cheap. I cracked my side of my case a bit when drilling a hole
and I just want a easy replacement for it.
If you want something tougher, try polycarbonate. Also available at HD or at many plastic suppliers. You could also try getting thicker acrylic.
If you cracked it, you may have been pushing too hard. Let the drill finds its own way through - it doesn't take much force. Make sure you have sharp drill bits and don't go too fast.
