Where to get Standoffs
Fangman
Hey all,
So I am going to rebuild the computer with a motherboard replacement and I need to buy more standoffs. Previous ones have become damaged or lost so I need a new pack. Looking around I found 1 type at Maplins but not the correct size. I was hoping people could tell me where to get one of the correct size. In the UK.
It is 5mm screw with 10mm top (hope that makes sense).
It is for a Thermaltake Kandalf case.
http://imageshack.us/photo/my-images/151/dsc0013hg.jpg/
This isn't my photo but it looks very much like the one of the far right.
Thanks!
I have some Lian Li? standoffs screw length is 5 mm, nut height is 8 mm.
Find a pack and use them with washers to get close enough to youR height?
You can, if careful, crazy glue a washer to stand off so you will not have to worry about "lost" washers, Nylon motherboard washers should also work.
2.5 mm screw length should be more than enough to secure standoff in case.
Screw is #6-32 thread.
Sent a message to Thermaltake asking for advice and quoting the model number. Reply back today saying they would send out the standoffs via post free of charge.
Nice of them.
Very nice gesture by Thermaltake. I'll take a second look at their cases when I'm considering a new one.
