Where to get Specialty Wire?
Im looking to get some transparent purple 18-20 guage wire but I cant find any place that sells specialty wire at thise guage. Closest to what I want is Stinger SWT16PUR. Its for redoing a PSU.
Anybody know a place that sells specialty wire?
Also does anyone remember the thread where the guy redid his PSU with a blue-metallic wire?
Link 1 is some type of craft wire.
Link 2 is wire management.
Link 3 has the stranded hookup wire I want but not transparent purple/metallic.
Thanks anyways.
Is there a reason why 16awg is too big? There's really not that big of a difference, unless it's solid conductor.
Not exactly the mettalic/transparent effect I was going for.
Its unbeleivable that this type of wire is so scarce.
So you're looking for something like this but smaller and in purple. I'm sure it's out there and I hope you find what you are after. Are you planning on making all the wires from the PSU the same color?
edit: Sorry I didnt notice that you had already found what you want in 16 Gauge, just nothing smaller. I dont see a problem with using 16 Ga unless it's fitting the bundle to the solder point on PCB in the PSU.
Yep I need to fit the wire on the solder point on the PSU. Thusly it would be very cramped with 16 Ga wire.
