Hey all. I just got a Antec Minuet case. It is freaking sweet. Unfortunately, due to its small size, it is extremely hard to find a window kit to fit it and I don't have the modding skills to cut plexiglas in straight lines...heh.
I would guess I need about a 9" by 7 1/2" or 8" oval or rounded square. Heck I'd be happy with a 8" circle window. I'd also like a rubber-grommit surround type window.
If you don't feel like looking up the case, it is a flex-atx style case with the glossy black sides like the Sonata.
Also, for lighting, since the case isn't even 12" high, are there constant-on blue or red LED strips I can get in like 3"-6" size just to get a little bit of light? Or is there a cheaper alternative?
I don't know if you guys saw that EL AMD logo on FrozenCPU, but it is ridicuously cool.
I would appreciate some opinions on what I could do to make the case a little cooler for LAN partying and make it a little more of a conversation piece.
If by chance you're interested, since I'm not made of money, and this being my 3rd most powerful PC, it is a:
Athlon 1Ghz (200Mhz Socket A)
Asus A7N266-VM nForce1 mobo
512mb PC2100 ram
40gb Maxtor 7200rpm HD
48x $8 CDROM
Using onboard LAN, graphics (GF2), and audio
Dlink DWL-520 WLAN-b low-profile card
512mb PC2100 ram
48x $8 CDROM
