Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I need a piece of... something that's 0.78mm thick, with +/- 0.05mm precision. Doesn't matter what, plastic, metal.. anything goes. I need this to make a shim for my CPU. Thanks!
You can usually find this under "precision shim stock" ...There are a variety of places to get it....I would try mcmaster.com 1st. MSCdirect.com seems to have a large stock of materials/hardware as well....
if you use a ferrous metal.......something magnetic.....just cut it out and get the thickness close......if you aren't over 1mm send it to me and I'll take it down on a surface grinder
