Where To Get PC Window?
Pre-made windows? You mean side panels with the window or the plexi glass itself? You can find plexi at home depot and they'll cut it there for you as well. If you're looking for side-panels with the windows, good luck. You'll have to find manufacturers that sell the side panel with the window specifically for your case.
Cheers,
Maplewalnut
No I mean they sell pre-made kits to do your own window online. Comes with like the window, molding, and a stencil.
I've been checking out frozencpu.com. I would appear that they wil try to combine shipping as well, so I'm just putting together my list before ordering.
