Where to get extra side panels
Im looking at getting a new case (the wave master frame) & modding it but i want to have extra panels to change out or when i mess it up. I have looked & even e-mail cooler master & they replace we dont sell parts for case. Is there a place to get them or should i just go with a Lian-Li that i can find side panels for
For that price I would just go Lian-Li if your really worried about it. Unless for some reason your really attached to that case.
But really just take your time while cutting and you'll be fine. I just started on mine and messed up once already. My cutting disk got "kick-back" and bounced out onto the surface I did not want to cut into (have a black Lian-Li, and under black is silver) so there is no room for error with this case. But I was smart enough to tape it ALL up and it just cut through a bit of the tape... I was soooo worried when I pealed back that tape, but it was all roses under it.
you can see about half way down the "wrist" the little triangle of tape removed this is where it happened.
What is that etchin you to cut? I read another thread that your dremel got over heated? It happened to me once, I was using those no frill cookie wheels. Those shit almost F up my dremel, so I went to Home Depot and got me the genuie dremel cookie( cutting wheel). No probel ever since :D
ITs THIS
You can also see here the little triangle that is not present is present in the above pic, that is where I almost fucked up.
