where to get extra 939 brackets?
strikeout
i just got a gigabyte matx board but the stock bracket uses plastic achors. These anchors only go halfway out. You can pull the bracket off the mobo but you cant pull the anchors out the bracket. I would like to use an aftermaket cooler that needs the standard bracket holes with screws i.e ninja and zalman. Does anyone know where i can get a hold of standard top and bottom bracket with appropriate screws?
Probably eBay.
I scored one there for a Socket 478 system that I broke one of the retention arms.
If you buy aftermarket heatsink fan units, they usually come with the entire bracket needed.
Unless you don't want to replace your stock ones ...
My Zalman 9500 came with inserts to replace the nylon inserts (take out the nylon inserts and replace with the pieces that came with the kit, screw in from back of mobo and attach Zalman), so you might not need to buy a replacement bracket.
the problem is that i cant take out the plastic inserts to replace it with the zalman ones. I'll try frys.
