I got a generic dremel at a place called The Chirstmas Tree Shop in New Hampshire. $20, came with the rotary flex extension, a bunch of bits, case, etc. It was fully adjustable rpms too, been using it since Thanksgiving, works great.
Dunno if they have a website, and their inventory changes weekly, so not sure if you can still get one from there.
how much should one expect to pay for an actual dremel (corded, powerful enough to do necessary modding)? I recently seem to have busted my cheapo $20 nikota tool, and I am trying to decide whether or not to go for the real thing this time, even though the cheapo tool served me well.
Walmart has sales on them from time to time, the last one had them going for about $35. I have to go out there next week so I might pick up a new one if they are cheap again.
I was just going to say to check Pepboys, there is a dremel like tool there for under 20$.
I dunno if normal dremel bits will fit on it though.
If i was you, I would wait till you see a Dremel (Brand) on sale or something and buy that. 20$ is cheap, but makes me think it will not last as long or has as many features like varible speed.
