starsfan7 said:I don't want to parallel that because I'm going to screw either my VGA, or my CPU, whichever is second.
zer0signal667 said:Not really, there's very little temp change before/after each block... With parallel flow, you''re splitting flowrate, also. That's bad for heat transfer.
Top Nurse said:Yes, but if he has a EXOS II design where it is a native 3/8 system AND you want to use their blocks then you probably have to split your lines to keep the flow rates at an acceptable level. Their CPU-300 cooler comes in 3/8 ID and all their other blocks are 6mm (1/4") ID. So the way to fix it is to use a Y splitter on both ends of the loop that Koolance makes.![]()
like i just said that will kill flow rates..... run it in series. trust me.BellaCroix said:I wish I still had the linky... there's a company that makes exactly what you're looking for (although I agree it's not a great idea). It was basically an aluminum tube with a series of compression fittings mounted down it's legth. Supposedly it would keep things more tidy by allowing each device to have it's own feed line. I'll look around for it and if I can find it will send you a PM.
Ctrl_Alt_Delete said:like i just said that will kill flow rates..... run it in series. trust me.
look in my profile under occupation if you dont beleive me
