i need some standard SATA molex power plugs so that i can rewire my power supply, the wires are WAY too long. i cant for the life of me find any website that sells only the crimp on plug ends. every search turns up half a million results for adapters of all sorts, even ebay is useless for SATA power connectors.
im looking for this- which i believe is the in-line-crimp on, i also need some of the type that terminate a cable end...
http://www.molex.com/molex/products/datasheet.jsp?part=active/0675820000_CRIMP_HOUSINGS.xml
if anyone knows of a secret website that sells this stuff it would be appreciated. digikey had nothing, mouser had no products from molex stocked. thanks.
