I have a cabinet that I am now putting my pc in and it doesn't have any means for hot air to escape, so I have to cut a hole in it. I'll put an 80 or 120mm fan where I put the hole most likely. Now, should I put the hole near the top of the cabinet, since heat rises? or should I just put it directly behind where the outtake/psu fans are on my case.
I was thinking put it at the top since I will eventually change my case one day...
