Where to buy replacement IHS for 4690k?
Discussion in 'Overclocking & Cooling' started by spacetim666, Nov 25, 2017.
  1. spacetim666
    spacetim666 n00bie
    2
    Nov 25, 2017
    Hi I'm trying to find a replacement IHS for my i5-4690k because my friend seems to have somehow bent my original IHS out out shape during a delid that even though the CPU still posts and can boot into windows the bent out shape IHS seems to be causing severe over heating issues even with liquid metal... anyway I need to find either an aftermarket IHS that's compatible with the I5-4690k or a original IHS from a Haswelll or Devil's cayon CPU that isn't bent out of shape and is compatible with my i5-4690k any idea where I could get one?
  2. Speedeu4ia
    Speedeu4ia Limp Gawd
    394
    Aug 7, 2017
    eBay has copper ones cheap
  3. spacetim666
    spacetim666 n00bie
    2
    Nov 25, 2017
    I'm only seeing ones made for Skylake and Kabylake... Do you think Skylake/Kabylake is close enough to Haswell that it would work with My i5-4690k?
  4. Speedeu4ia
    394
    Aug 7, 2017
    Someone else will have to answer that
  5. DaCoOlNeSs
    DaCoOlNeSs [H]ard|Gawd
    1,473
    Jun 8, 2004
    I believe the Skylake and Kabylake IHS are slightly thicker due to a thinner PCB, so it probably will not work without shaving some off
  6. Neapolitan6th
    Neapolitan6th Limp Gawd
    404
    Nov 18, 2016
    My only thoughts would be buying a dead chip off ebay. Snag something from a dead pentium chip (not sure if the IHS would be the same)
  7. newls1
    newls1 2[H]4U
    3,702
    Sep 8, 2003
    why not leave the IHS off, and just mount your cooler direct to die?? Obviously be ultra careful with mounting pressure, but ive had excellent temps with direct die cooling in the past
