picked up a nice piece of 18x24 at home depot for $6.97. It is a bit larger than I would prefer but, I will be experiementing tomorrow on the cleanest way to cut it.
Thanks again for all the help.
SIGN SHOPS DAMNIT
goto sign shops with CNC routers and say "cut this by eg 300mm x 900mm at 3mm thick"
if you want to be fancy you could get them to lightly etch a design into it so when you insert an LED through a drill hole at the bottom of the panel the design will light up.
