i had no issues with the ice parts.
You must be lucky...even in the dome inside the enemy camp, when you get underground and the "accident" happens, frame rate drops as soon as the ice appears. As soon as I leave the dome, it goes back to normal.
Also depends on what res you are playing at....at high res, any ice causes a massive drop in framerates. What settings are you using?
I only brought up normal performance in the past because someone else mentioned that they used to think of 80FPS as being standard. I agree that it's not relevant and that's exactly what I wanted to point out.Why don't you crysis apologists just cut to the chase and say, back in the stone age, we just had rocks, therefore be happy that we get this performance with crysis. it would shut everyone up!![]()
I have a 3700+. 1Gb and an 8800GTS and I would like to be able to play the game at 19x12 with everyting at the highest setting, and get 100fps framerates. Or else the game sucks and COD RULEZ!
That's pretty much where discussion of this game has gone. Every thread gets derailed and sucked into the exact same issue. IBTL
With everything on Very High except Shaders at high and shadows at medium at 1280x768 res I get 25fps average. It honestly looks significantly worse than COD4 at that point. The game is a mess, half the time different story cue's don't occur, and many other problems. AI bugs where they literally won't see you uncloaked, etc. Its unplayable. Sure, if you have a low standard for the game then you could force your way through it, but I plan on waiting until I can enjoy it so I don't get sick of it before I can max it out. Of course that looks like it will be a while, if a patch they claimed would take 7-14 days is taking a month and a half.
These days Im running in 1280 with all settings to high, no special configs. When I first played through the game, I ran it at 22' native WS.
The only noticeable slowdown with the ice was when I was right at the dome wall, other then that, I didn't have any problems.
Try that at 1920x1200, ice WILL cause 30 to 50 percent drop in framerates.
Cant say im suprised, why did they have to open their mouths before when they said about 2 weeks its gonna be out.. yeah right they are starting to be valve giving dates and cant follow them..![]()
Patch Delayed until mid-January...
See the related thread on [H] http://www.hardforum.com/showthread.php?t=1255106
I was really looking forward to this too...![]()
I still don't see how you can say that 30+ FPS average on HIGH with an 8800GT, GTX, Ultra at a res of 1600x1200 is anything but remarkable in a game that graphically makes everything else out there look 1-2 years dated.![]()
Exactly. I think a lot of the people here never even had to deal with Quake 1 or any of the classics. Textures weren't even filtered and no one complained!
Even when the first Quake 3 and UT came out, I could barely play them at 320x240 and I was still impressed by them. Years later we could get over 300fps. People just aren't being realistic.
you don't have a single SS from an actual gameplay moment: Take some with enemies around, actually playing the game, not just points in the level or scripted instants.
I can get close to 30fps, 1600x1200, everything on very high at certain points (even in assault crysis!) of the level, away from enemies and everything else.
In actual gameplay, that drops to 8fps, with things going on around me. If even.
never said you didn't. you just run 1, a massively overclocked system in every aspect, and 2, a custom config that sacrifices visual quality in some areas that drives me nuts. I've always thought your config looked pretty bad compared to normal high settings. At least from my looks at my screen.
You're really the only person getting performance like that provable though. [H] review agrees with what most of us see: Certain levels especially are unplayable.
You are grossly mistaken, couldn't be more wrong in fact.
1. My settings are ALL HIGH, except for Shadows and Post-Processing, which are set to medium.
2. My custom config only consists of 6 lines, all of which are settings to make it look even better, not worse.
EdgeeAA
Sunshafts
XY_view_distance
Water tesselation
and (occassionally) parallax occlusion mapping
are all I have tweaked in my system.cfg file, and that is only to enable them and/or increase them from their defaults.
I think you are seeing what you want to see.
That's all High, with the aforementioned settings enabled (POM is off in those screenshots), and 16x AF is enabled as well for that matter.
That just happens to be a rather open area of the game, and I am also taking damage in a few of those shots, so it looks blurred.
Ive posted other SS's before, and have had about a half dozen PM's noting how good it looks, and people wanting my custom .cfg file.
EdgeeAA
Sunshafts
XY_view_distance
Water tesselation
I don't know why you are arguing so fervently in defense of Crysis or Crytek. The topic says that we're looking for a patch that was promised. If we have a problem with it, so be it; we do. If you don't, that's too bad; you should have never even come into this thread.
Second, your screenshots look like a**. Sorry, but we're supposed to take your word for it? I can make any number of screenies and then say that they are at settings that they truly are not. With those settings you are claiming, my Crysis looks far more different and detailed. As a matter of fact, while I'm at it, I'll admit that I'm running an 8800GTS, but that's besides the point. I played the game, enjoyed it (except the ending), but what everyone here is claiming is absolutely CORRECT. There are some parts in the game where one setting will work and another where it will not. Point in case: The entire first 1/3 of the game I played on Very High settings. The next 1/3 I had to lower to Medium, and then as soon as the ice/snow started showing, I had to lower EVERYTHING to Low. This screams UNOPTIMIZED. For no reason at all, I had to lower settings. I can guarantee you that vegetation requires more graphics horsepower than ice/snow does.
So regardless of how many FPS you are getting on YOUR rig, you're in the mass minority. Can it and keep it to yourself. You had no place in this thread to begin with. We're looking for a patch and whatever good it may contain. We've a right to complain and bitch about it; we paid for the damn game. I frankly don't see any uneducated or dumb people making frivolous/unsubstantiated claims about having problems with the game, so their arguments stand.
you were originally posting in one of the custom config threads, namely Cuban's. My bad. Cuban's config looks like total shit, so I assumed you were still using it.
Either way, you're still an extreme statistical anomaly. If I have more than one guy on the screen in many places, especially outside, I'm in the low-20fps range, with everything on medium, at 1152x864, let alone 1600x1200 or anything reasonable. The [H] review shows this. who knows why it runs well on your system: It doesn't run well on most of ours, and that's honestly all I care about.
edit: Aren't you also running 32bit DX9?
I doubt Im a statistical anomaly, as I have posted about half a dozen different reviews/benchmarks from reputable sites who have tested with hardware similar to mine and can in fact mimic my results.
And no, I'm running the 64bit DX9 version, in Vista X64.
I just finished installing it under XP X86 today (dual boot), and I usually get 2-3 FPS more on average compared to Vista X64, but the SS's posted are the 64bit DX9 ones from Vista.
Can it and keep it to yourself. You had no place in this thread to begin with. [/B]We're looking for a patch and whatever good it may contain. We've a right to complain and bitch about it; we paid for the damn game. I frankly don't see any uneducated or dumb people making frivolous/unsubstantiated claims about having problems with the game, so their arguments stand.
With all due respect to the rules here at [H] and the mods keeping this place going, you ajm786, can blow it out your ass.
This isn't your topic so I don't see where you get off telling anyone that they don't belong in a thread.
You think that a thread talking about a patch is a free for all to bash a game, if so, then its just as much a free for all for us to defend it.
You seem to have some personal thing against Crysis and anyone who runs it fine.
I have a slower system then you and yet the game run and looks great for me...Perhaps you just can't run a machine worth a damm. Numerous people in this thread have said the same things about Crysis working fine, and yet you crap on it about hacks or whatnot.
Some are saying it runs and looks like shit, dropping X many frames when doing this or that and some of us, are simply pointing out that its not always the case.
Considering that this other guy was posting screen, frames, config and whatnot, and yet you offer up no proof to support your claims.
No offense or anything, but this is a public forum and you have no right to tell anyone what they can and cannot post.
Now, you'll have to excuse me while I crack open a painfully expensive bottle of champagne to celebrate the start of my long weekend.
Happy Holidays
I'm running it in DX9 also. Just because I'm not stupid enough to run it in a mode that looks the same and runs much slower means there's something wrong with me? I can use Very High settings in Windows XP at better frame rates...so why wouldn't I?And on a real level, like Assault_crysis or Relic_crysis, not just out in the open on the first level.
And like I thought, you ARE running DX9. Try it in DX10.
Also, I didn't have enough time to play this game a lot, but if you or someone could send me saved games from the start of every level, I'll gladly take screenshots from there with High or mixed High/Very High settings to give you an idea of how it runs.
Oh and to my knowledge, the ice parts are probably slow simply because ice/snow use different shaders - most likely reflective ones - so it would make sense to run slower. Also, don't leaves and things shatter when frozen? I'm sure that affects performance also.
I'm running it as shipped: One shouldn't (imo) have to throw commadn line flags at something to make it play well anymore, but after fiddling with things forever, I guess I should expect it still. The whole DX9/DX10 config hacks is a whole different beast though: I expect you'll find all of us with performance problems are those of us running it as-shipped, where it forces to DX10 mode without some fiddling.
I can get you saves, I expect. I think I still have them backed up.
Ice is not reflective.
a) Do NOT, I repeat, do NOT run it in DX10 mode.
That's when the game runs like crap. Even I will be quick to admit that, and won't bother defending it.
On the other hand, I am just as quick to defend the fact that for those of us such as myself (and apparently Droc and Frozen to name a few), DX9 mode runs great.
b) The ice isn't really reflective per se, as you alluded to, but it does glisten.
forward me your custom cfg: carmichp AT colorado.edu
I'm going to do a direct comparison on my 8800gt. DX10 vs DX9. I have a feeling most of us with poor performance are running in DX10 mode.
Im not saying Crysis doesn't run bad on some systems, and Im not here to contest the claims of poor performance, myself and some others are simply stating that its not always the case. Im a guy with an average system who hasnt done anything fancy, I dont have low standards and I run the game fine and it looks great.
Happy Holidays
