where is the nvidia control panel
wesleys_dad
Im confused as to where the control panel goes or is it even installed...
I installed an evga 7600 gt o/clocked edition video card in my wifes computer and if i install the drivers off the cd the control panel is where its suppose to be...then i go to the nvidia site and download the latest drivers for that video card there is no control panel anywhere..she uses dual monitors as she does work from home...ive googled the problem and control panel is not in any of the places it is with the drivers off the cd..
Im an ati guy mostly so im confused with nvidia ....
is there a seperate download for the control panel?
its not in control panel or in display settings and not on the task bar by the clock,,,
also she is running vista business edition if it makes any difference.....
anyone have any ideas....
Right-click on your desktop, and about halfway down the menu it should say "Nvidia Control Panel".
At least, that's how I do it in XP.
Yea i know thats where its at with the cd driver install but not there when i install the newest from nvidia...confuses the heck out of me....
you access the nvidia control panel the same way, regarless of where you downloaded it from. did you not uninstall the old drivers before you installed the new ones?
No i didnt uninstall the drivers first,ill try that and see if its there....
its got to be something im doing wrong...thanks for the input sir....
