where is my task manager?
klumb
the only way i know how to get to the task manager is to right click on the task bar, and select 'task manager' from the list. now when i try that, it doesn't start.
1 what happened to it?
2 is there another way to get to it?
thanks
Control + Alt + Delete...
And if that doesn't work.. you should probably start looking for virus and malware issues...
