Where is my CMOS reset switch?
Nice try with the pic, but there's not enough detail to matter.
It's probably a 3-pin jumper near the battery. Take the battery out, switch the jumper to the other two pins, give it a minute, put everything back like you found it.
BTW - do this with the power off, not just the front power button, but the power switch on the back of the PSU too. Let it sit off for a minute before you mess with anything inside.
Bonus points for the ISA + PCI mobo, haven't seen one of those in about 3 years (thankfully).
Gary King said:
Okay thanks! I'll look around.
You could always just remove the battery to clear the CMOS. It looks like an oversized watch battery and just pops right out, and right back in. Its the shinny silver round thing upper left corner by the IDE cable (In your picture)
Probably time to replace the battery anyway, so if all else fails, remove the battery for the same effect as the reset.
