Where is everyone getting their Plexiglass?
My girlfriends dad owns and runs a acrylic factory. but that's probably not much help to you.
I've used home depot plexi on a few builds. Just make sure you don't get a scratched up piece.
This is not a place but the product itself. I always get the Acrylite FF stuff from a local plastics shop. Maybe there are others, not sure. Just look around in your phonebook or google it for sign shops or plastic fabrication.
You can find it much cheaper locally if you look hard enough.
If you look up any glass stores in your area, they most likely also carry plexiglas.
Plexi is a very versatile material, and it can be used for hundreds of applications. That being said, plexi generally comes in large sheets like 3x6 ft or 4x 8ft.
When doing work, 90% of the time a whole sheet is not used, so the rest are generally either scraped, or sold at a extremely cheap price.
The place I go, you can get any scrap you want, for $1 (a piece). I have gotten tons of 1/4" thick plexi mainly 24" square pieces for $1 each, which is by far the best deal you can get.
Search locally, I am sure you can find something.
K-TRON
If you don't need a ton, I have gotten scrap plexi from the local ACE hardware store. They sell sheets there too.
