Where do you buy good cable combs from?
doug_7506
I recently purchased these cable combs. They ended up breaking (the comb wasn't thick enough for the wire) when I tried to push the wires in.
I would love to get some clear plastic ones that are a little more sturdy.
I purchased my last ones from performance pcs. They were black and made out of cardboard. They broke when I tried to add my sleeved cables to them. For reference I had purchased these in size A.
I got the same in size B and they seemed fine, had to peel off the brown stickey paper. On the large 24pin ones if you are trying to work the cables after you have them installed you can snap them but otherwise mine have been fine. Seemed to be plastic to me.
You can get them in different colors.
Yeah after reading up on it some more, looks like i just purchased the wrong size....
I have some aluminum ones by Gosumodz that I bought from mainframecustom.com. Unfortunately they've been out of stock of the 8-pin ones for months. I gave up waiting and bought a 3D printer to make my own, lol.
I've tried a few and the Cable Mods ones have been the best for me. They're not brittle like some of the other brands, and they tend to fit nice and snug on the sleeved cables I've used them on.
literally ebay. They have cheap 3d printed ones made of ABS. it cost like $10 for a bunch, just remember to only buy the ones from the US.
The cablemod ones are good quality.
Overclockers UK do some but that finished quality for the acrylic aren't as smooth.
