Where do I get replacement fans: Shuttle sn25p
DthInd
The cpu fan set up seems to have lost one or both of the fans. I am guessing they are 25x5mm and 40x10mm (again guessing).
Any idea how I get two new fans for the system ?
They both spin, but I cant really tell if they are spinning enough. If I open the case and point a fan in the direction of the air flow, the system runs fine. Once I close the case in a short period of time the system locks.
I'm no rocket scientist, but I am guessing this is a heat ain't leaving fast enough problem.
I didnt see the fan size in the manual or the specs so guessing and buying something after market probably will create more frustration than it is worth.
Thanks.
Do a search on this forum. There is a mod for adding a 120mm fan to the top of the case. (or maybe it was sudhian forums) I did that to mine, and it worked great.
Only problem I got with my sn25p is the power supply. I couldn't find a replacement online anywhere. Ended up putting in an order with shuttle to get a new one, but they aren't sure when they'll be in stock again. I really like the shuttle size, but next upgrade, I'll be going with something that has a power supply that is more readily available.
