where can i put a fan?
You seriously made a whole new thread to ask where to put a fan? Fans blow on things to cool them, so you put it so that it will blow on the card. You can figure out where to put it without someone spelling it out for you.
xnikx said:
where can i put a 80mm or 120mm to help cool gfx card?
Right by the card. ;)
What card is it? Passive cooling? That case should have decent air flow already.
what is wrong with the fron 120mm fan? if it isn't puttin out enuf CFM then get a higher rated one.... :rolleyes:
lol thats not blowing onto the gfx card, tahts pulling air away from it
btw, for which direction to have the fan, just put ur hand in front lol.. the side that has air blowing is the right one :p
i dont get how its pulling air away and not blowing onto the gfx card, wasnt it just doing the same thing when it was in the front? and both sides have air comin out.
btw i put the side with the 3 things i showed facing the gfx card. so i thought it was blowing on it.
how should i set it up so its blowin on the card?
Its a EVGA 8800GTs
http://www.newegg.com/Product/Product.asp?Item=N82E16814130071
Yes that is the right directional flow.. Across those three things.
Edit, If you need more you could try one of these
Or you could cut a 120mm hole out in your case exaclty where it wold cover the cards top and bottom. By looking at it, you'd have to go through the window and some of the metal.
Neither, you defineltly don't want to reverse the exaust fan at the back of the case, everything else in the case will run hotter. If you reall want better temps you need to put a fan very close to the video card. Maybe drill four holes in the very bottom of the case and mount a fan there, or cut out a 120mm hole there and then four holes. That would work.
Edit, Maybe try to zip tie a fan somewhere to move air over it.
xnikx said:
theres alrdy holes at bottom of case but how will that help cool the card?
this is the part that is gettin hot
http://img85.imageshack.us/img85/4079/e6fc5.jpg
If you put a fan there and raise it up off the case so air can travel through the fan, you can have the fan facing directly on the card.
EDIT..Ok you need to cut out the side of your case and have it blow over BOTH sides of the card.
xnikx said:
i dont want to add another fan unless i have to.
also i moved the fan up a slot so its furter above the gfx card?
Keep in mind i moved the fan on the inside so it is blowing on the gfx card.
http://img445.imageshack.us/img445/9083/bafj0.jpg
http://img171.imageshack.us/img171/2934/ba2kd3.png
also the cd drives have little holes in them but there is foam inside them. should i take the foam out?
how big of a concern is this? i touch the card and its very hot.
Yes where you moved the fan up one slot will help a little, but not much. And to answer your question about the foam, I'm not sure.
How does the card run? Are you having problems with it? If not I wouldn't worry about it.
The card runs amazing. Everything at highest settings on a 20.1 widescreen. No stuttering, crashes, lock ups. ect. I have lock ups on the sims 2 but thats the games fualt happened on my old comp too. The only prob is how hot this side of the card gets.
What i was thinking of doing is not buying or doing anything, and if the card doesnt die by the time my warrenty is up i should be fine?
Can i download something that tells me the temp of my card?
You could download Nvidia's Ntune software. That would tell you your GPU core temps. It might even already be on your motherboards driver cd.
Edit. Nvidia monitor is the portion of the software that would tell you.
Ok first off. Do you have it overclocked? If you don't, you have nothing to worry about. If the card fails, you can send it back. I'm not sure if 60C is too hot or not. You might have to ask in the video card section. I have a 7800GT. Not an 8800.
I would not worry about the red and yellow boxes in your screenshots. And just for a comparison. Here is my screenshot. Look at all my red boxes. http://img451.imageshack.us/my.php?image=tempszu5.jpg
Another thing. Are you getting artifacts while gaming?
im not ocing, and idk what u mean by artifact but if u mean boxes that pop up, no.
Aritfacting is something like seeing alot of different colored confetti(spelling) not normally seen. When the card starts running too hot it will artifact. You'd know it if you ever seen it. So if you don't see any artifacting, it should be running cool enough.
LOL. Your PSU is fine. Your pc is fine. Your pretty new to this stuff right? My appologies for having you try that nvidia monitor. Maybe I should have had you use coolbits or some other program. Seriously, just run it and enjoy your hardware. :)
Nice rig for your first one!!
I also went back and read your posts in the nvidia forums. Your psu is SLI nvidia certified, Nvidia certified it meaning it's capable of runnint two cards in SLI. Also, your psu has two rails with 18amps. You can double that and get 36 amps, and you only need 20 for your card. All is well my friend.. And this is the last time I will tell you this. Your rig is running normal.. You have nothing to worry about. Good day.
ok but whats wrong with the memory? what is HT(SPP-MCP)? and how do i bump to 36amps, or 20amps?
Give me a link to your memory.. And to answer your question about your psu. It's already at 36 amps. You have what they call two rails that put out 12 volts. They both have 18 amps. Like I said it's already running at 36 combined amps.. You don't need to do anything.
I'm not sure about the HT(SPP-MCP). You'll have to post in the Intel side of the forums. Sorry I can't answer that one.
Your memory according to your screenshots of Nvidia monitor is saying it's at 1.9 volts. These are new eggs specs as according to Gskill's recommended voltage..
Tech Spec
Capacity 2GB (2 x 1GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 5
Timing 5-5-5-15
Voltage 1.8V-2.0V
Heat Spreader Yes
Notice the voltage says 1.8V-2.0V..Yours is at 1.9 directly in the middle.
and u say 2 rails( wich i think r the connectors? ) combined equal 36. i only have one connector in the card?
No two rails means inside the psu. Each connector has 12volts with 36 amps. Your card only needs one connection with 12volts and atleast 20 amps. Your good to go.
