where can I find mesh?
I dremeled out big box shape hole on my case
I want to put a mesh to cover it out, but i can't find what I like
I'm looking for ones like on CM stacker, small holes,
any ideas?
My local hardware store sells mesh for 33 cts./ft^2 Yours probably does too! It's the same mesh they use when doing sheet-rock and insulation work. (i.e. very small holes)
Ebay motors. Really they have modders mesh, its just not called modders mesh.
I'm currently locked out of the room with the digicam in it. Post pics tonight when the key arrives.
my.php
my.php
Holes are a mm wide, maybe two.
I went to staples and found a.... file holder, desk organizer or whatever
it's made out of exactly same grill as the one used on CM stacker
I found my grill :D
Black trapezoid shaped thing? My little brother wouldnt let me take his apart, so I had to go to the shop on the corner and buy what you see in the post above...
