Basically, I need more air to cool my 6800GT. However, those PCI fans do not work, at least for my setup. What I'm looking for is something like the exhaust vents in the steel brackets that are on the back of the fans, so I don't just have an open PCI cover.
If that description sucks, here's a what I'm looking for. I basically edited out the fan from a photo. I ONLY want this part, nothing else. A two slot version would also be perfectly acceptable.
Does such a thing exist by itself? If not, I'll just cut-up some nylon screen and tape that in (yeah, it'll look bad on the inside, but I only open it up to dust and upgrade)
Sorry if this isn't the right section.
