And that's very unlikely to happen. There is basically only 120*120mm where the fan is located. No 120mm rad can fit here without cutting or modifiying...MassiveOverkill said:I may also upgrade the water cooling if I can find a decent radiator that will fit internally in the 120mm space of the Q-Pack.
floflooo said:And that's very unlikely to happen. There is basically only 120*120mm where the fan is located. No 120mm rad can fit here without cutting or modifiying...
Actually, after browsing the forum, I've discovered a watercooled Q-Pack. A radiator was cooled by a 120 mm fan. I thought someone had found a 120mm radiator that fits and I was amazed. But finally, after a carefull look, I noticed that the radiator wasn't at all a 120mm radiator. It was more like a 92mm radiator cooled by a 120mm fan.El Nacho said:not true. Check out the gallery. A couple people have done it with out hacking up the case
PC-HAngover said:Well ZZF put the Asus ones on their product list.. its listed as "back-order"... which means its coming soon!
6150/430
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=247026
6100/400
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=247027
Whoops, sorry about not mentioning price. I'd say something that's $150-250 including shipping.Soymilk said:give a more definite answer of your price range for video card, and people will be able to give you an answer. "not too much" doesn't give much info. whats the price range? ~$200? $300?
