Where are all the E6 Processors?
Surely ewiz still has them. However e6 are crap OCers IM[H]O I had 2.
You want 0520 E3 Venice. Known to average 2.8 :)
54YW4T said:
they are bad OC'ers? shit.
Again that is my experiences. However if you do some searching you will find that lots of folks didnt get very good results out of the e6.. However Im sure some did. YMMV
There is a big ass OC database somewhere but cant think of where off the top.
as always, ymmv. some E6 are good, some suck. same goes for E3. one thing i can say though.. it seems that the E6 chips run cooler.
the problem is that i didn't think to differentiate between E3 and E6 in that database :(
serbiaNem said:
If it helps, I'm pretty sure all 4400s are e6.
i'm certain they're all E6 toledo's. there's no choice ;)
same with the 4800+'s and all the dual core s939 opterons.
the 3800+, 4200+ and 4600+ can be manchester or toledo. just check the OPN, BV = menchester, CD = toledo :cool:
Somewhere deep inside I knew I was right, I just didn't want to go giving false info. :cool:
