You were thinking of the IBM T221 right? The manufacturer of the panel was IDtech - some sort of joint venture between Chi Mei and IBM - but they closed down in 2005. But they invested a lot of time offering products with high DPIs and high resolutions while also using IPS technology.This would be a very good resolution. Perfect for 1080p content and perfect for work.
I have seen some incredible expensive products but when will this be available for reasonable prices? ever?
don't get fooled by high resolutions, the quality of the screen is defined by many factors.
If you look at the screens of today you'll notice that 90% of all monitors have at least one big flaw.
If you go looking in area's that are in this case quite experimental, you'll end up paying much for nothing...
It will cost more than sperm of a nobel peace price winner
We already know you hate high resolutions and think the current situation is just fine for everyone, so this probably isn't the right thread for you.
If you built a 4K screen at the pixel density of the iPhone 4, I reckon you'd get a 3840x2160 16:9 display in about 13.5".
The iPhone is designed to be used at about 12" from your face though.
Because the 1080p resolution is the first to deliver enough detail to your eyeball when you are seated at the proper distance from the screen
You guys want it just think of how much freaking GPU it will take to push those resolutions in games dont even get hopeful Eyefinity will be awesome at those res.
You might as well forget about it. The cost increase would be enormous and could never, ever be justified through any application outside of medical imaging. 3840x2160 for office work? Really?
In terms of connectivity though... is there a cable type that would be able to drive that resolution at 60Hz or higher? Is there not an issue with image bandwidth in that sense? I'm curious to know how we would connect such monitors to a base unit.
how would it help 1080p content, it would be like watching a dvd on a 1080p monitor and make it look like crap.?
For 1080p content, it'd just be blocks of 2x2 pixels so it would scale perfectly.
I think you lack imagination. 2560 x 1440p is possible but 3840 x 2160 is a flight of fantasy? Yeah not really.. It's not a problem at all from GPU standards either. A 6950 (2GB) can push this today in some games imagine how easy it will be in one or two years. I think most folks that use a computer have figured out that more pixels is helpful - not just a larger size. So this is a natural progression for the high end buyer. Apple caters to these wealthy people so they will be the first to use this when it comes out. I'd expect to see a company start making 3840 x 2160 panels for better 30 inch display. Didn't apple drop their current 30 inch ACD display?
When they introduce a new one it will fill the void - and probably cost around 2 - 3k. Let's hope its not glossy though.
There is no reason for that resolution unless you want a 40 inch on your desk. I would like to upgrade to that some day...
I have found an interesting article called LCD Monitors: Why we're stuck at 100 ppi.
Interesting read. I like how the poor guy is predicting 21" 2560x1600 displays for the start of 2010, and Vista to come along and fix all Windows' scaling issues.
Windows 7 scaling is underrated.
Sure if by important applications you mean Microsofts applications.
Hardly any applications I have scale correctly at all, they just fall back to blurry-zoom.
Well most modern applications should scale fine. Microsoft has great development tools and most developers can use them.
