samsung.204b
- Aug 6, 2006
will 64bit vista be adopted in the same time they release vista 32bit? should 64bit drivers and applications be available at the same time too?
QTF. I see vista as more of the "transitionOS" into 64 bit. By the time the next version of windows comes out (2010 at the earliest I'd imagine) we'll be seeing more and more 64 bit stuff to the point that we should be close to full conversionswatbat said:I'm thinking that the round after vista will be the big turning point to 64bit. By that time all of the procs should have full 64 bit support. I just don't think we will see vista being the switch os.
I believe it does. It was listed in the MicroCenter ad when I bought mine.Xaeon said:Does Core 2 Duo have full 64 bit support? That's the one thing I haven't seen mentioned anywhere I've read about it. (Admittedly, my research time has been extremely limited.)
samsung.204b said:will 64bit vista be adopted in the same time they release vista 32bit? should 64bit drivers and applications be available at the same time too?
ameoba said:What do you mean by "adopted"?
There's still bajillions of machines out there running 98.
duby229 said:As soon as sheeple stop whining about "we dont need it" "How many peple actually use 4gigs of RAM?"
I say if your building a new computer today, build it 64bit. The fact is that most of us that visit [H] are already using 2gigs of RAM, and the next upgrade cycle we will be at 4gigs.... Then you'll be kickin yourself in the head for not going 64bit.
Build smart, not what others tell you.
Catweazle said:There's quite a difference between "have 4 gigs", "use 4 gigs" and "need 4 gigs". We won't be seeing a situation where systems with RAM in excess of 2 gigs are coomonplace until such time as you see entry level preassembled systems sold with that much RAM as standard. That won't be happening until such time as basic, everyday computing activities require that much RAM to be installed in systems. We won't be seeing 64-bit Windows become anything other than an "option" for mainstream users until that all occurs.
Sure, it's an essential item for people who run certain software. Sure, it's an attractive option for enthusiasts who want to specc their systems up and maximise benchmark results. But those things don't legitimise blanket claims which suggest that 'everybody' should be fitting massive amounts of RAM and using the 64-bit OS installation. Not everybody who visits a board such as this to seek advice is a 'hardkore' enthusiast and following that advice isn't necessarily 'smart' for everybody!
So what about all the people who currently have no need for 2 GB of memory, such as my-in-laws who check e-mail, browse the web, and print out pictures? It certainly would be a waste of money for them to buy 2 GB of memory.duby229 said:If your building a computer today, and you build with less then 2GIGS... Well needless to say you shouldnt be building anything.
Again, I'll go back to my example above. I'm building them a budget computer. What would they need 64 bit computing for?duby229 said:And if anyone is NOT building 64bit today then it is there own fault come next year when they find out how expensive the required upgrade will be.
You should heed your own advice. Building smart means building for the needs of the owner/user. You are failing to remember that not everyone out there is a member of a forum like this, where high end computers are a must. Do you really think 64 bit will be the primary platform within a year? It will be yearS before anyone with only a 32 bit machine will be "left behind". Take a wider look at the computing industry as a whole, not just a tiny group of enthusiasts.duby229 said:Build smart, not what other people tell you to.
djnes said:So what about all the people who currently have no need for 2 GB of memory, such as my-in-laws who check e-mail, browse the web, and print out pictures? It certainly would be a waste of money for them to buy 2 GB of memory.
djnes said:Again, I'll go back to my example above. I'm building them a budget computer. What would they need 64 bit computing for?
djnes said:You should heed your own advice. Building smart means building for the needs of the owner/user. You are failing to remember that not everyone out there is a member of a forum like this, where high end computers are a must. Do you really think 64 bit will be the primary platform within a year? It will be yearS before anyone with only a 32 bit machine will be "left behind". Take a wider look at the computing industry as a whole, not just a tiny group of enthusiasts.
That was your comment, duby229, and it doesn't restrict the suggestion to only "enthusiasts". Intentional or not, it was a blanket statement which suggests that everybody should be building systems which include 2 to 4Gb of RAM, and stating that most visitors to [H] already have such systems.duby229 said:As soon as sheeple stop whining about "we dont need it" "How many peple actually use 4gigs of RAM?"
Catweazle said:And I quite honestly believe that it's a misconception to assume that anybody visiting a message board to ask questions is necessarily a [H]ard(kore) enthusiast who cares about little else other than bench test scores, even if that message board has an [H] in its name! Anybody assuming that mustn't be reading the posts made very carefully at all!
