When will my PC be considered ancient?
zombix
I just built a new pc from what i could afford just about 3-4 months from now. Im hoping that it will last me a long time.
Im just wondering when my PC will be seated next to the cave man as Ancient history.
Specs are in my signature
you should be fine for 3-4 years IMO, a lot of people on [H] think they need a new pc every 12 months :eek: but that is what makes them [H]. I wouldn't worry about it to much....just use it until it won't play games at the level of eye candy you want or until parts start crapping out.
Also the life time of a pc directly depends on new software. If new more taxing software doesn't come out for another 3 years then you should be just fine, or if the new software isn't something you want to use then you are fine again. It all depends.
My rig in sig is pretty old, but I don't consider it "ancient" to me. Why?
Well, I've given up on having the cash to support my PC gaming hobby, so the midrange card of whatever NV has out at that moment works for me (Linux user, so ATI = no). Aside from the transitition to High Definition content, my machine works just fine for my stuff, and its at the point where upgrading would just let me get things done faster rather than a necessity to handle new HD content. But I'll definitely say I need to leave single-core land ASAP. :D
for the average user on this forums ever 18 months is good..... but honestly its like every 6 months here sometimes.
thanks for the feed back im glad that my limitations of funds for my PC habit is going to last me longer then i thought...
I now declare your computer so ancient, even a caveman wouldn't use it. :D :D :D
Naw, just playing, since your rig is a LOT better than mine.
I still love my P4 though. *Hugs Mr. Pentium4* :D
