When updating bios ...
Macca
I need to update my bios for my MSI K8N NEO2 PLATINUM... should i just get 1.3 .. or get all the ones before and use them all?
You only need the newest. Each time you flash it totally replaces the BIOS, so flashing each one just increases your chanses of messing up and killing your board.
==>Lazn
Wait are u saying that flashing your BIOS simply has a higher chance of killing your board because you are simply flashing or are you saying that it actually decreases the lifespan somehow. I always thought it was rather safe to flash a new BIOS.
Theres a tiny chance that while flashing the bios that something could cause the bios to corrupt (like a power out or blue screen), but generally you shouldnt be flashing an unstable board anyways. Ive always used a version of winflash and never had an issue.
if you're BIOS gets corrupted then how do you fix this?
Well, specifically I stupidly flashed the same BIOS 1016 over 1016 for my mobo. Now when I overclock with a 5:4 spread I get a blue screen when the HDD boots into windows saying
"BIOS or driver error on new hardware and check newly installed device.." etc or something like that.
This never happened before the flash. I would be able to get to boot and run rather stably at around 240-250 fsb, just not prime stable at some instances.
does this mean I've corrupted my BIOS, because it works fine as long as I run my settings at stock speeds.
Flashing the same BIOS over the same BIOS should not do anything but reset your BIOS setings. My guess is that if you can find what in the BIOS you had set that let you run at the higher FSB and change that back to it's old settings, you should be fine again. (eg: If you had increased RAM voltage and forgot to reset it after flashing)
==>Lazn
Exactly.
While it does use up one of the Flash memory's limited writes, the rewrite count on most flash memories is between 100,000 and 1,000,000 times, so no real worries about flashing it too many times... Rather it just increases the chanse of somthing like a power outage happening durring one of your flashes.
==>Lazn
