When to expect triple PCI-E boards?
S_G
I was pretty intrigued by the article [H] had up about ATI's new Havok physics processing system, but I found it funny that they were promoting a system running CrossFire X1900XT + an X1600 as a physics processor, meaning they were running 3 cards at once.
Are they sending this out to motherboard manufacturers yet? Do they even have a new chipset ready for it? ATI seemed to be all show, but not much actual information about when and how Havok will be implemented.
Intel's 975 board has 3 PCIe x16 slots and is crossfire ready. Wow... it's almost as if they planned this. :D
Which one, the bad axe 975? I got a rev 304 board here, but I haven't heard that the slots were all 16x. I read somewhere about different configs though.
They are physically 16x, but run as follows...
16x
0x
4x
or
8x
8x
4x
Depending on your configuration. If it's physics you're worried about, the third slot can be used as a physics card, but I'd wait until true triple 16x exists on the RD600. The chipset probabbly won't be anywhere near as stable as any Intel chipset, but will be much better for the overclocking power-user.
16x
0x
4x
or
8x
8x
4x
eh... there is no way the bandwidth of the physics card NEEDs even close to x16. x4 would be more than sufficent.
A lot of boards have 3 pcie slots.... evga for instance....
Are you refering to the Aegia Physics board? If so, that is only a PCI card, not a PCI-e. So they wouldnt need 3, unless you are talking about a different physics board.
most boards already have 4-5 pci-e slots ;)
just not all of em have 3 16x slots... im sure it be possible for ati or nvidia to release old cards in a pci-e x4 format, you never know
No we're talking about ATI-as-physics right now.
AFAIK the RD600 will support 3 16x slots.
Now, granted, they may not all run at that speed, but it will have that many slots in order to support 3 GPU's.
The D975XBX has supported this configuration from the beginning; now we know *why*. What I found rather fishy was that every other motherboard manufacturer (when quizzed by the INQ) begged off on implementing it. Considering that BadAxe has been shipping for a while now, their reasoning is getting smellier and smellier. First off, the only *given* is that the form-factor can't be mATX or mBTX; full-size BTX or ATX boards (BadAxe is full-size ATX) certainly work. It also does NOT obviate or block Ageia-based PPU solutions (as there are both PCI and PCI-E x1 slots usable, even in a three GPU configuration). It doesn't even require Conroe (note that both the original XBX and the current 302 both support three GPUs, and neither is Conroe-ready). Then finish off with the fact that BadAxe costs less than other *enthusiast* motherboards (even those with the same chipset).
Given that the tech not only exists, but is currently shipping (and the cost of implementation is certainly not a real issue, given that the D975XBX costs less than other motherboards with the same chipset), it will be showing up elsewhere; the question is not *if*, but *when*.
