When should I flash the BIOS?
Gar
Just setting up my new comp tonight, I have a DFI NF4 UT SLI-DR and I was wondering if I should flash the BIOS to the latest version before or after I install Windows and all my drivers and whatnot.
Or does it really make any difference either way??
No it doesn't really make a difference. It will reset all the bios settings and you will have to redo them. So doing it first will save you time. ;)
Only flash the BIOS when the new version provides something you want/need over the one you are using. (EG: last time I flashed the BIOS on my MB was when they did a temperature correction for the CPU sensor)
Otherwise don't bother.
==>Lazn
I used to flash the bios whenever I saw a new one available and never thought twice about it. Until I flashed my ITX board recently and the flash failed making my mobo a big paperweight. That sucked :mad: , no more flashing for me unless absolutely necessary.
Most new boards have backup bios chips, so its pretty safe. Find out if yours does before you flash. ;)
agree, although i've not had a flash go bad...yet :rolleyes:
