Hi. I'm having a problem with streaming movies from my pc (XP service pack 1) to my xbox running XBMC. Here's the deal.
I've been using my pc as a file server for XBMC. Everything was working fine. I could stream without a single hitch.
Then i go and buy a wireless adapter so i could play online with my PSP. Installed the card and after reading a 'how-to guide' about setting up the pc and psp for online play, i ran the home network wizard. It detected all my devices and things were looking good. At first. The internet was working fine. but i couldnt stream movies to my xbox anymore. The connection seems to timeout in XBMC. (My Xbox is connected with a crossover cable to an NIC in my PC by the way.)
Next thing i did was unbridge the connections. That didnt solve anything. So i deleted the connection and re-installed the network card. Still nothing. I re-installed the streaming software (CCXstreamGUI v1.41). Everything is setup correctly but i cant stream anything anymore.
I'm stumped. No idea what to do.
The last thing i want to do is have to re-format, so is there anyway of restoring my connections? (I dont use the system restore feature in XP)
For instance completely deleting the network and starting from scratch?
Dont know how to do it. Looked on google but every tutorial is about setting up a new network. Not getting rid of a bad one.
