When is Intel ending i7 920 production
Sherloc
I'm wondering this because i'm building a new rig here in a month or so and my local microcenter has only 14 left in stock. Should i expect them to get another shipment before xmas?
I was posting in an early i5 thread about how MC ran out of the 920's. However, the next week, they were restocked by Tuesday/Wednesday...so I would expect them to keep restocking for a while.
Either way it can't hurt to get the i7 now if it is at $200 because I seriously doubt it will ever go lower.
MC sells the 920's at a cost loss to entice you into the store so you buy other items where they can make the money.
At $200 you'd be stupid not to go the i7 920 route if you have a brick & mortar Microcenter nearby, but it is not an every day normal retail occurance.
i7 will probably reach its peak end of the year, followed by a slow downward slope next year and the middle of the 2 1/2 life span something "new" will pop up via AMD or Intel and at the end of its 3rd year it will probably be "old-tech."
However, my Q6600 is still kicking and I see nothing worthwhile to replace it with, nor do I really have the cash either. :p
Just my thoughts.
So, yes. You'll see more i7 for some time.
I want your opinion guys, I have a 920 CO does 4GHZ everyday but takes 1.4v`s to do it. Should I buy one of these D0 $200 920`s or should I hold out and just get i9?
You're not losing much (apart from e-peen) if you drop it to 3.9Ghz and can dramatically reduce vcore. Definitely not worth buying a D0 just to eek out another 100-300Mhz though. That money is better spent on GPU upgrades.
really?
I have a CO and I am still @ 1.2v w/ 3.8Ghz.
Does it really require 200mV for an extra 200Mhz? I never pushed it that hard because of my mediocre Zalman 9500A
Here is an old screenshot of beck in march when I was running 3.7ghz under the same voltage.
What kind of volts does the D0 need to run 4ghz stable?
I bought my 920 in November of last year. It was one of the very first production runs so it takes more volts than most. I will wait I guess till i9 comes out and see how well they OC.
you'd probably be safe disabling the system pagefile; i noticed a huge difference when doing so on 6GB...
